Hello, always been interested in electric propulsion and I have obtained a Cintura Dynamo chinese ebike 250w (I think) 36v 10amp (again I think) battery. pedal assist and a throttle. Battery sits at 42v charged. It has intermittent running problems either no go or max power when switched on with no throttle or pedalling. I've pulled the controller from the bottom bracket and cleared out the damp sand. I'll check all the connections once I identify where/what they do and hopefully rectify the problem. The front Wuxxing led light seems to have a component missing. It lights if I connect the wire (36v) to the back of the led circuit board however it appears that there should be battery or fuse installed between the wire and the board. This seems to be the size of a AAA battery but shorter. Can anyone shed any light on this.
Yes I really want a Stealth Bomber ;-)
