Hi thanks I will pop back to the shop at some point and ask them on the black oneThe red piece is to insert between brake pads if you remove wheel or calliper, the black piece I've not seen before but expect its an expander in case you apply the brake lever with wheel/calliper removed and need to pry the pads opens.
