Bbsxx gear change sensor
KirstinS
3,224
899
Brighton
The gear change sensor that is available for newer bbsxx models
Does anyone know if it is compatible with gear hubs like an alfine 8 ?
Or just deraileurs ?
Cheers
Cheers
Yes. The new ones work with either whereas the old ones specified either igh or derailleur.
I've got one you can try if you want to test and see if you like it.. :)
Sent from my E5823 using Tapatalk
Hmmmm! You shouldn't need one for a hub-motor. Do you have a problem with the motor running on after you stop pedalling? it might be better to get a new controller.
16,440
he may have a BBS kit running on his Alfine IGH.
I prefer to adjust (reduce) stop delay and stop decay or dab brake on the certain shifts and generally only when on higher assist levels. Shifting between 4th and 5th gear as it changes planets being the worse offender.
16,440
I have never seen the need to fit gear sensors to CD bikes but some members on the forum constantly beat up the CD bikes on account of noisy gear change so I gave in, start fitting gear sensors to the new batch of my CD bikes.
To me, the risk of the gear sensor failing is much more than the occasional banging when you shift gear under load.
Sure, can quite understand that.
Correct gear usage and practice helps a whole deal, bit it's fair to say that not everybody appreciates that!
The new BBSxx motors are coming through with built in cable for gear sensor connecting,but for my taste the delay is too long.
Perhaps more needed on large 1000W mid drives, but less so on the 250W I think.
Reactions: anotherkiwi
KirstinS
3,224
899
Brighton
Thanks for replies. I am building a 26 inch hardtail with an alfine 8 hub
It won't get electrified until much later in the year. But I just wondered if it was compatible
But the intention is to have a bbsxx and an alfine 8, yes
5,785
Kirsten you have lots of experience and I think gear sensors are meant for people who have never ridden a bike before and have come to cycling via pedelecs. I naturally, without even thinking about it, ease off on the pedals when changing gear and since the GSM was mounted last summer have crunched the gears twice(?) maybe even once, OK I don't even remember if I have...
That's because you're a light guy. you need to see things from other people's perspective. As the total mass goes up, the forces and momentums go up too.
Same thing, as the motor's power goes up, so does the amount of crashing and damage done when you don't get it right. A BBS01 probably doesn't need one, but they're definitely worth fitting to a BBSHD. On all variants, it makes your riding more enjoyable with one less thing to worry about.
tommie
1,760
600
Co. Down, N. Ireland, U.K.
No you don't need one,
have the exact same setup myself, BBS02 + Alfine8, just pause on the pedals, up/down a gear and away you go again.
What i did notice though with the Alfine 8 is to get your cable from shifter to where it enters the hub as straight as possible, any sharp bends delays the downshift.
KirstinS
3,224
899
Brighton
I am totally getting that I don't need one.....but why not, I don't see any downside . It's 25 quid and might save a chain or two at the very least over time. May also save it prolong an alfine
But I really thought I had posted a yes/no answer
I love that we have such different views and discuss them
I am all about zero maintainece and less to worry about
On balance im inclined to.stick one on
Recy
103
17
manchester
How do these sensors fit - same as an in-line brake cut off ie just run the outer cable through it?
Or do they require a bare inner to be run through?
Recy
103
17
manchester
So why not just use an in-line brake sensor?
Would seem to do the job and connect up nicely to available socketry to. Also inexpensive.
Would it work?
16,440
brake sensor works only one way, when you squeeze the lever.
Gear sensor works both ways, when the inner cable moves.
Recy
103
17
manchester
Two in-line brake sensors (£20 a pair) - one facing one way (fitted on to the existing Bafang gear sensor on the BBSHD) one facing the other (taking up 1 brake sensor or use a y splitter at the handlebar end)?
If that works = simple, inexpensive, reliable.
16,440
there is a little pressure put on the innercable for movement detection. The sensor adds a tiny but still measurable 'slack' in the gear shift cable. If you think that half a millimeter out of true is all it takes to ruin your IGH, you don't want any slack in the line.
It doesn't work. They'll both stay on, so you'll get no power after you attempt to change gear. With the brake, the cable goes in both directions to switch on then off, but the gear cable moves then stops.
