Best LEGAL 250 w hub motor for hills for DIY
Simple question, but complicated answer. Every motor is different and has plusses and minuses.For best climbing you want a slow wound motor and higher voltage. The 48v Xiongda is like a winch. That brings the next question of what is legal. I'm sure that if you ask Xiongda nicely, they'll give you a 250w certificate.
The Q128 is also pretty good at 48v, especially the 48v 201 rpm one. Some would say that it's an 800w motor, but it's the same size and shape as any normal 250w hub-motor, like the one used on the Cyclamatic. It has a llabel that's easy to peel off.
Reactions: alexsally
8,219
My silly sticky label peeled off on my Q128C and now sports this small tiny plaque.
Quite nice for £2.99, only problem is the slight spelling mistakes :rolleyes:.
Reactions: anotherkiwi
1boris
343
58
After more thinking I belive it has to be the 250w Ezee motor.it comes with a certificate.
The Xiongda 48v vould be the best but Bonnie told me before she could mark the motors 48v 250w .but they only had an En 15194 certificate for the 24/36 volt versions.
also the Bafang swx02 should be good,but i havent seen it as a diy kit anyplace.
Reactions: mr watts
8,219
Woosh sell 250w SWX02 kit.
John_S
161
29
A 48v 250w BPM motor with the lowest available winding speed (code 16 I believe) would be an excellent choice for hill climbing. I'm not sure how easy this motor would be to obtain though. All the 48v BPMs I've seen anywhere online are all rated 500w, and it seems to be difficult to request a specific winding speed from most sellers.
A 48v Q128h at 201 rpm would also provide for excellent hill climbing, although this motor is rated 800w. However, it is the same size as most legal motors, and the 800w label on it can be easily peeled off.
16,423
I am bringing in switchable 36V/48V kits, one of them is 250W BPM, later this month.
8,219
spanos
244
64
Hi Kirstin,
Ebay of course, I will find the link. As you can see up to 4 lines of engraving approx. 20ish letters max per line. Delivery is 4 days, you have to order the plaque then message the seller with your engraving details.
http://www.ebay.co.uk/itm/ENGRAVED-TROPHY-PLAQUE-Name-Plate-BRASS-SILVER-self-adhesive-label-25mm-x-50mm/182778421757?ssPageName=STRK:MEBIDX:IT&var=690092624707&_trksid=p2057872.m2749.l2649
But of course!
Though I couldn't find one so thanks for the link mate! :)
Btw - don't spelling errors make it more rather than less authentic !
Reactions: Wheel-E
5,785
davidg
26
11
54
France
Is it still the Bafang Bpm/cst 250w?
On road, off road?
At what gradient? speed?
My 250 watt GS Moon will climb hills round here ok (10% grade, 1000 meters vertical, 18 kph) without overheating, the battery doesn't like it much though.
minexplorer
532
93
55
Four Lanes,Cornwall
Wow not a single mention of the bafang bbsxx midrive kits.Thought they were supposed to be the all round best choice for hills,price and reliability.Never saw any of these others when i was looking into kits.Must have been in my adhd hyper focus mood lol.
16,423
that honour should be bestowed onto the Bafang SWX02 or BPM geared hub motors.
They're good for heavy off-road stuff.
They're a bit too powerful for the drive-train, so you can expect to do some repairs to that from time to time, plus their controllers have a nasty habit of expiring without any obvious cause at some point in their life.
They're quite good fun to play with, but I wouldn't want to use one for a long daily commute.
Their extra power means that you need a good (i.e. expensive, though cheap compared with a Bosch or Yamaha one) battery. That battery will be relatively heavy, so the heavy motor and battery detract from what makes riding a bicycle good.
