Bosch Battery Rattle
Rich_uk
134
49
58
West Midlands
My battery has an annoying rattle when going over bumpy ground, I've looked and can't find any way to adjust/tighten up the lock, I noticed there's a little rubber pad on one side of the lock, should there be one on the other side too?
6,319
if you take off the plastic you will find this under it.
as you can see there is a bit of room to adjust it up or down just make sure you use some lock tight on the bolts so they dont move again ;)
Brian park
38
52
Is there any way you could post this image of the adjustment again? for some reason it has gone from the post.
