Can I limit the power used by the q128c with the S-LCD3?
Davidwed
Nov 2, 2017
england
Hi,
I have the Q128c 201rpm 36V motor along with a 36V battery and 20A sine wave controller from BMS. I'm looking to restrict the power to 250W but having read the manual can't quite see how to do it.
I tried lowering the C5 value (which i believe is the current) all the way to zero but the power its putting out is still around 600w when going up hill.
Can anyone help?
Cheers.
It's dead simple. Set the controller to current control (torque simulation mode). Each level on the LCD will then be a different power. Level 1 will be about 100w, level 2 about 160w, etc.
Why do you want 250w? There's no legal limit on how much power you use.
Davidwed
Nov 2, 2017
england
Great thanks d8veh, I had seen toque simulation but with the translation I wasnt too sure, I'll have a play with it. I thought the legal limit was 250w so was trying to make my bike closer to being road legal.
Benjahmin
2,478
1,691
69
West Wales
To be legal, the motor should be rated at 250W continuous and labelled as such. That is, it's capable of taking 250W over an extended period without overheating. The amount of power it actually consumes is dictated by the controller. In your case 20*36=720W maximum. Absolutely fine and not against the law - at present. Lower pas settings will deliver less power.
If a member of HM constabulary ever tests these parameters, please do let us all know, 'cos I'm sure we'll all be fasinated to know how he/she does it:D:p
5,785
With the Q128 it is easy - look at the marking on the motor and if it says "500W" you are nicked...
harrys
294
64
73
Chicago, USA
Have you tried C5=03, which the manual says is 50% of the current? I haven't installed my S12S controller yet, which is 20A too.
harrys
294
64
73
Chicago, USA
S12S is normally 28 amps!
You're closer than me! Mine says 25A on the label. The thing is almost a foot long, just to hold all them MOSFET's. Well, that's rounding error. Maybe it's 7 inches, almost twice as long as the little PSWpower controller anyway. A third of the case is really empty too. I gotta use it one of these days.
