Cheap Brompton Conversion Kit?
patpatbut
859
79
Btw I also did what Dave suggested. Everything is boxed and mounted on the stem apart From the battery. I only need to unplug the battery connector to the controller when charging. It is a lot easier
Bernard Manansala
41
10
51
Took my new rig out for a spin and it runs perfectly. Fells like 15mphs which is perfectly fine especially for my size. I may have to swap the chain set since I have a climbing set-up.
Question for everybody...
What kind of preventative maintenance is there for this type of hub. Judging by the size I assume it's a geared hub.
Reactions: LeighPing
patpatbut
859
79
Make sure the screws on the hub is tight and sealed especially the disc rotor screws. The water can get it and corrode the motor.
No maintenance is necessary unless you plan on doing 30,000 miles or more with it.
Bernard Manansala
41
10
51
Sometimes, they don't put the PCB in its slot properly, which allows the PCB to touch the case. I've seen that a few times, luckily before they were powered up.
Bernard Manansala
41
10
51
New controller should be arriving this week but I am concerned about splicing the correct wires together. Power is not problem, it's the Phase, Hall Sensors, and Cadence wires that I'm concerned about.
patpatbut
859
79
It should be straight forward as they are colour coded. Phase wires are a lot thank than hall wires so you won't them mix up
Bernard Manansala
41
10
51
At a certain point this "Cheap Brompton Conversion Kit" is no longer Cheap.
Purchased the wrong controller to replace the one I fried.
Bernard Manansala
41
10
51
Here's an update on my build...
Hub motor failure. I think one of the internal gears is grinding away. I can hear something rattling around in the housing.
New Black Q100 motor
New controller and working on a centralized mount similar to the Nano2 Kit.
patpatbut
859
79
That is what I am using and I am really happy with it. Very quiet running at 36v 328rpm
D8ve
2,142
1,294
Bristol
Nice
patpatbut
859
79
You are using the bigger controller box. Maybe you can switch to smaller one that makes it flimsy. Mine is smaller one and it fits all the connectors in.
Also, how about mount it on the front stem tube? It works on mine and looks neater
Bernard Manansala
41
10
51
I would like to use a smaller case but it's all the excess cable that I had to deal with.
