Cheaper bike
denwyn
414
41
After having to pay out for tow bar and Thule bike rack I have had to cut my bike budget, looking more and more at Woosh. The crank drives interest me, but I see a fair few coments on poor gear changes on Woosh crank bikes, only crank drive bike I have tried was test ride on Gepida berig 1000 with Bosch electrics,and that was fine . Would I have probkems with the Woosh system, what is build quality like on Woosh bikes, I know there not up to Kalkhoff build, but you pay for that. I'm not against hub motors, but being 16 stone, 5' 9" they keep recommending crank bikes or the Big Bear, latter looks way to bulky for me. Any advice on Woosh or other bikes appreciated, under the £1000 bracket please. Thanks
trex
7,703
2,671
the full sus sporty Bear would suit you best but it'll be end September or beginning October.
hoppy
330
50
I seem to be the member who has the job of reminding others of the Tonaro range! I suppose because my Compy has been so good.Super value too.
trex
7,703
2,671
the Compy does have good look and climbing power but denwyn lives in Taunton, not particularly hilly. The Kudos Tornado would be perfect but he's allergic to Kudos. Also, his budget is now reduced. The new Bear will have hydraulic brakes and still under £1000.
denwyn
414
41
No its not that hilly in Taunton,I'm not against a Kudos, just had bad experience with the City bike i bought from them, not there fault, bike was fine, it was me who found it to tall to ride,other than that it wasnt a bad bike. Wont get into any discussions re the Kudos City at all, its dead and buried now. Re the Bear, I do think it will be to big for me, plus im not keen on front wheel motors. Need to get this right, didnt really want to buy without trying, but my lower budget means I will more than likley have to. Bikes I have tred and found right size are Batribike Granite Pro, Freego Hawk, and Gepida Berig 1000, the Batribike was nice, partner has bought the Diamond Pro Xl, wont buy Granite though, there is no way we wil go out for rides on matching bikes, plus I dont like the bright colour anyway. Gepida is to expensive, and unsure on Hawk.
trex
7,703
2,671
I know the current Big Bear is not your style, but the full sus Bear will have the BPM motor at the back, the rear suspension protects the spokes and it will come with front and rear Tektro hydraulic brakes.
denwyn
414
41
Sounds interesting, I may wait and see if Woosh put any details out , although I had hoped to sort something sooner, before she finds another use for the money . I have looked at Kudos Mountain bikes, they are the best looking M bikes out there in the price bracket, but I see they have max rider weight of 100 kg, I, m about 5 kg over that, plus would not want to stress the bike out all the time. So im not adverse to looking at Kudos.
JohnCade
1,486
736
I've got a Sport Cd and Woosh build quality is okay but not up to the standard of higher priced bikes as you'd expect. The equipment is down to a price. The gears work fine with a little care, but you have to think ahead and cut the power uphill by stopping peddling for a moment or touching a brake lever. So a work around for what is really a slightly crude way of doing things. But again it's not Kalkoff money.
Though I'm coming round to the view that I should have paid around double what I paid for this for something like that, and got a really good bike of the sort I was used to before....
I'll probably end up doing that at some point. People do say that first electric bikes are not usually keepers but are more like sighters.
You can't ride the bike in the way I like to by keeping a steady cadence and changing gears constantly to suit. So I find myself getting out of the saddle and staying in a higher gear on hills rather than changing down too soon and going up slowly. Though you might think that you'd be using less battery by putting in more pedal effort and going faster uphill I seem to use up more that way....
On lower power settings the changes are smooth enough even on downshifts. But on 5 it's a bit clunky changing up in the lower range however you adjust the the mech and feather your pedaling because the power from the motor means that the mech is a bit inadequate for it really. Probably the only way to get a really smooth upward change is to keep it in a lower power setting or cut the power like you do when changing down if using 5 max setting. But that's a drag really. I've bought an SLX mech for a very good price that I'm going to put on instead which should be better I hope.
So all in all a good bike for the money but with the inevitable compromises that you'd expect for the price. Oh, and the brakes are crap, but the newer ones are better apparently. Though I only bought this bike a month or so ago.
Reactions: RobF
Kudoscycles
Official Trade Member
Apr 15, 2011
5,566
5,048
www.kudoscycles.com
Denwyn....re the Kudos Tornado,a completely different riding stance to your Kudos City.....dont worry about the 5kg weight,I am 17 stone and ride the little Kudos Secret bike a lot,its just being sensible and no bunny hopping off kerbs.
We have a new dealer in Weston super Mare,DS Automotive....his full details are on our website,he will keep a Kudos Tornado in stock for test rides....Helen C has just bought a Tornado from him,I think she is pleased with it.
Hope that helps
KudosDave
RobF
4,732
2,311
On lower power settings the changes are smooth enough even on downshifts. But on 5 it's a bit clunky changing up in the lower range however you adjust the the mech and feather your pedaling .
Same applies to the Bosch system, changes are clunky on higher power settings so I tend to avoid doing them.
Soft pedalling all other changes keeps the job right.
denwyn
414
41
Thanks for your very detailed and frank explination, its made up my mind to steer clear of Woosh crank drive bikes. I do understand my budget means cheaper components, but dont think I could live with the gear / crank issues on the Woosh. I never noticed them on the Gepida I tried out, but then again it was onlya 10 min fairly level ride, oh and more than twice the price of the Woosh.
denwyn
414
41
Hope that helps
KudosDave
Hello again...bet you thought you had heard the last from me, thanks for letting me know about your dealer in Weston Super Mare, I must have missed thay on the web page. I will give him a call to see what he has. I like the look of the Tornado, also the next model up the Arriba. I like the idea of being able to view and try before buying. Just need to be sure im ok on it, oh and at 66 I need to make sure im ok with the mountain bike style. Will give them a call and try and get out there this week
JohnCade
1,486
736
I'm a bit surprised by that. I thought the higher end CD bikes had cunning software which adjusted the power for smooth changes.
Kudoscycles
Apr 15, 2011
5,566
5,048
www.kudoscycles.com
John,all crank drives with derailleur suffer from clunky gearchanges,the higher the power the worse the change-its asking a lot of the derailleur system requiring to lift the chain,when its under load.
As others have pointed out,when you are riding a non assisted bikes by the very nature of cycling there is an arc of rotation of the pedals when the load is eased,allowing the change. But with an electric bike the motor load is constant not allowing a point to execute an unloaded change.
The Bosch system minimises the problem,especially on generation 2,but at the expense of uphill momentum.
It was for this reason that we made the decision to either go BPM hub drive,or fit the Nuvinci hub with crank drive,the latter allowing fully under load changes.
KudosDave
30,349
The current Kalkhoff Impulse systems also minimise the power transmission ill-effects during gear changes, claimed to be with minimal loss of drive due to the very short period of it's function.
C
Cyclezee
Hi Denwyn,
You can check out Tonaro crank drive bikes at Powerpedals in Exeter which is not a million miles from Taunton.
http://www.powerpedals.co.uk/
I would recommend the eZee Sprint Primo at £850, but Milton Keynes is way too far from Taunton for test ride;)
Helen C
44
21
66
Hope that helps
KudosDave
I'm absolutely delighted with it. The hill-climbing is beyond my expectations. And, Dave at DS Automotive couldn't have been more helpful.
Oh, and as for your worries about style, Denwyn, as a 57 year old woman I'm quite happy with the mountain bike style ;-)
-H
JohnCade
1,486
736
I wasn't trying to put you off but you did mention the gear issue. Actually if you don't want to ride it in a sporting way, and are happy to leave it in the higher gears and change down in advance when you need to it really isn't much of one. Particularly if you don't live in a hilly area like I do.
I think you were looking at the Sirocco CD which has a bigger battery than my Sport CD and would deliver a bit more power and a lot more range.
Alchemist
44
I can certainly attest to the functionality of the impulse 2 shift sensor system, which eliminates the described problem. I would urge anyone sufficiently curious to go and try one out themselves - no crunching of gears, just smooth changes. Recommended!
