Connecting SO6S controller, Q100H wheel, LCD, Thumb throttle
camerart
140
9
Dorset
Hi,
I've connected my new SO6S controller, Q100H wheel, LCD and the LCD shows battery full, OK.
The controller has a 3PIN black throttle plug, with wires: Red, Black and blue.
also a 3 PIN black speed sensor plug, with wires: Red, White and Black.
The thumb wheel socket is a larger 2 PIN white socket, with wires: Red, Black and White.
I tried connecting the thumb wheel to the throttle plug Red to Red, Black to Black and Blue to White, but this shows error on the LCD.
Any ideas? Camerart.
patpatbut
859
79
Can you tell me what plugs you have connected?
Photo would be nice.
This controller works on sensor mode only so make sure you connect the hall wires
Pat
patpatbut
859
79
Pat
camerart
140
9
Dorset
Pat
Embarrassed!! I had disconnected the Wheel to fit a tyre, before testing and forgot.
Once connected, it works fine, thanks. (I'll try to remove this if possible)
Cheers Camerart.
camerart
140
9
Dorset
The wheel is sitting in the bike ok, but the anchor washers aren't much use as there isn't a proper locking gap on the frame. The spindle is tight in the slot, but will it need extra locking? If it does, are there any spindle to frame locking clamps?
Camerart.
