Hi there ancheer ebike owner
So I used to be able to use this bike on full power, recently only lowest power setting is ok. Anyway recently whenever I put the charger into the charging port the light stays green indicating it's not charging or the battery has full charge (it doesn't it has 50% ish) and the journey doesn't last the length I need it to before bike starts cutting battery off. I've got a multimeter the battery itself is fine emitting 36v and 8ah like it should be. Any ideas on my next move is the charging port broken or is it the motor? Need experienced help has anyone experienced this before? And yes I've replaced the charger same thing is happening
