[em3ev] MAC 1000W 6T winding 30MPH, 50V 24.8Ah 29E triangle pack, 12fet 40A controller, CA-DPS v3
Bart
Mar 1, 2014
Almost new. Less than 6 months old. First run mid-March 2015. Not more than 900 miles on, battery - not more than 40 cycles on - charged to 90% and limiting discharge to 90% thus used only 80% of the available capacity. Very good condition overall. Plug&Play, tested, working.
HIGH SPEED MOTOR
Upgrade Mac in the fastest 6T winding (410rpm loaded at 36V or 50 km/h, 30 MPH on 700c wheels at 48V), 32 magnet 16 pole motor, internal 5:1 planetary gear w/ clutch. ~139mm axle width. 13G black Sapim Spokes with or w/o rim (pot hole damage)
CONTROLLER
Programmable 12fet IRFB3077 Infineon Controller 40A, half-twist throttle, 3 speed selector & cruise, bar mounted power switch & e-brake sensor for hydraulic brakes
HIGH POWER BATTERY PACK
50V 24.8 Ah ~1250Wh Triangle Pack build with High Energy INR18650-29E NCA cells (2C Max rated cell, approx 2.8Ah nominal Capacity). Not more than 40 cycles on - charged to 90% and limiting discharge to 90% thus used only 80% of the available capacity
CHARGER
58.8V 5A charger with a switch to charge to 100%, 90% [57.7V](extended life) and 50% [53.2V](storage). UK Plug
CYCLE ANALYST v3 CA-DPS
Opens up the possibility to have Motor Temperature Monitoring and Power Rollback if motor temperature exceeds a programmed limit. Allows on-the-fly speed, current or power limiting.
EXTRAS
9sp DNP freewheel w/ 4mm spacer for clearance, 2mm disc spacer (to clear the brake calliper), torque arm Rev4, battery bag
ORIGINAL PRICE SHIPPED, DUTY PAID:
1400GBP
ASKED PRICE SHIPPED:
1150GBP ONO
Video:
Listing: http://www.ebay.ie/itm/-/301741714109?
