Finally managed to join
Wrongway
71
Cumbria
Hi from Cumbria. Took a while but finally managed to jump through all the hoops to join the forum. I couldn't understand where the error was. It needed pedelecs and not pedalec. Can I suggest to the mods that you indicate which line is incorrect. I don't want to see another jigsaw again :confused:
As I am getting older I find bike riding, especially hills getting a lot harder so I am starting to look at e-bikes. I am hoping I get get a bit of guidance here as it appears to be a bit of a minefield. I had a trip to Halford last night but that will probably be the subject of a posting in the appropriate place.
Reactions: LeighPing
Croxden
2,134
1,384
North Staffs
The longest journey starts with the first step. Your journey has started, may you reach a successful conclusion.
phil01
63
25
66
Dartford Kent
I had the exact same problem. Took me ages to realise it had to be exact
  • Useful
Robbieg
188
71
66
Burton on trent
Hi and welcome Wrongway, Halfords may not be the rightway Wrongway, may be best to check out specialist ebike shops instead. Thisway you can most probably try out the different makes and models /styles. Once you have narrowed it down might be good to hire the one you think you like most and test it for comfort and fit for a couple of hours or so before making a purchase. Is good idea to go for a larger battery than you think you need because once you get the bug it's quite likely you will want to venture further afield. As with normal bikes, look at whether you need a rack and mudguards, rigid frame or suspension etc. Maybe a go anywhere trekking bike might be more suitable if like me you get fed up of traffic breathing down your neck. Good luck with your search.
Reactions: Gaz
