good bike to convert with disc brakes under £400?
Stu33
80
42
Hi,
So i bought a conversion kit, I like it , though i`m using an old bike with V brakes, i`d really like to convert something with disc brakes and pannier holes as the battery is a rack battery, any suggestions on a decent off road bike that can handle bumps well for less than £400 with 26" wheels?
regards,
Stuart
Alan Quay
2,351
1,076
Devon
Hi,
So i bought a conversion kit, I like it , though i`m using an old bike with V brakes, i`d really like to convert something with disc brakes any suggestions on a decent off road bike that can handle bumps well for less than £400?
regards,
Stuart
Have a look at the Carrera Kraken. Halfords have them at about £330 at the mo, which is very good for a bike that includes hydraulic disks, 27 gears and a lockout fork (suntour XCR I think)
Stu33
80
42
thanks for the reply Alan, that looks nice but forgot to add it needs to be a 26" wheel ! as my conversion kit has a 26" wheel
Alan Quay
2,351
1,076
Devon
If I were in your shoes, I'd have the Kraken and get the hub laced into a new rim.
Stu33
80
42
ok,i`ve asked if the people who i bought the conversion kit can replace the 26 inc wheel with the 27.5 , the Kraken looks good. i emailed the people i got the conversion kit off they said get a Carrera too. though i dont think they realised they are all 27.5
Reactions: Alan Quay
Stu33
80
42
thanks Tommie, that looks good too. how would i get cashback on it?
Stuart
danielrlee
1,348
689
Westbury, Wiltshire
torquetech.co.uk
FYI, your hub motor will spend more time opperating inefficiently, the larger the wheel you use. If you can avoid a lager wheel, both your motor and battery will experience less operational stress.
Also, at any given power level, a smaller wheel will give better acceleration at the cost of a lower top speed.
Reactions: trex
Alan Quay
2,351
1,076
Devon
FYI, your hub motor will spend more time opperating in an inefficient zone, the larger the wheel you use. If you can avoid a lager wheel, both your motor and battery will experience less operational stress.
You are correct, but from a practical standpoint the difference between 26" and 650b (27.5) is not enough to worry about. There will be about 0.5 mph between them, I'd be surprised if anyone could detect the torque difference.
danielrlee
1,348
689
Westbury, Wiltshire
torquetech.co.uk
Indeed, only about a 5% difference, but having the facts to make a balanced decision is never a bad thing. I personally would prefer the gain in efficiency and torque and would drop from 26" to 24" if I ever had to replace my rear wheel. If I only rode tarmac I would be running a 20" rear in a heartbeat.
trex
7,703
2,671
A switch to 24" would open up the possibility to use direct drive motors instead of geared hubs.
Planemo
201
80
Might be worth looking at the B'TWIN brand in Decathlon too. I bought my son one after looking through the Halfords offerings and believe they are exceptional value for money. I found they had better components than the equivalent prices Carreras. Failing that, you are pretty much touching into Specialized territory, which would knock it up another notch, and I have a lot of time for the brand.
danielrlee
1,348
689
Westbury, Wiltshire
torquetech.co.uk
IMO, a new bike almost never makes sense for an electric conversion. The warranty is as good as worthless after the bike has been modified and there are plenty of great used frames avaliable at great savings.
Planemo
201
80
I agree with Daniel, personally I would always build up my own bike from used components but some folks like the fuss free option.
Stu33
80
42
Hi Planemo i still have an old btwin rockrider 6.3 ,it can`t be converted though,no pannier rack mounts, i`m still fond of it though !
Planemo
201
80
I bought the Rockrider, 340 model I think for my boy, and yes you have to be careful if considering future upgrades with some models as his one doesnt have disc mounts on the forks or frame but for the money its a very fine bike.
5,785
Reactions: trex
