Haibike sDuro FullNine 29 2016 Yamaha 400Wh eMTB Frame 55cm eBike * SOLD/THREAD CLOSED *
Status
Not open for further replies.
James Woolfe
Dec 23, 2016
38
Milton Keynes, England
£2,195
CONTACT DETAILS REMOVED BIKE SOLD
Fast, agile with a travel of 100mm - the perfect compromise between efficiency and comfort: the SDURO full suspension model. Perfectly matched components, central seating position, and dynamic design.
The Bike is in great condition and has been cleaned with muc off, washed down and lubricated after every ride. Purchased in January 2016, 828 miles covered - and the most fun I've ever had on a bike!
Haibike SDURO FullNine 29 400Wh (Originally the SL model upgraded to RX frame) with around £1,000 of other upgrades - Rockshox 30 Gold TK Forks, Rockshox Monarch RT3 with debonair tune rear shock and RockShox Reverb dropper Seatpost , new pedals and Schwalbe Hans Dampf tyres)
Sale includes the full bike, battery pack, display, charger, original instructions 2 x keys for battery lock and shock pump. Collection from Aspley Guise, near Milton Keynes / J13 of M1. I’d be happy to accommodate viewings and deliver within 30 miles. Bike will only be released on receipt of cleared funds (bank transfer / PayPal) or cash on collection. For delivery, payment must be received in advance. Sale includes the full bike, battery pack, display, charger, original instructions 2 x keys for battery lock and shock pump.
Condition: Used – Very Good, several new / upgraded components:
Powered by Yamaha 250 Watt Motor
Full Spec
Frame
Alu 6061, Hydro Formed, Yamaha Gravity Casting Interface – XL (55cm) Black, Orange, Blue
Forks - Upgraded
Rockshox 30 Gold TK Forks - 29er - 2014 100mm - 9mm Q/R - 1 1/8"
Rear Shock - Upgraded
Rockshox Monarch RT3 with debonair tune (190x51)
Brakes
Tektro Auriga 180mm
Shifters
Shimano Deore Trigger 10 Speed
Rear Mech
Shimano Deore Shadow 10 Speed
Cassette
Shimano HG50, 11-36 Teeth, 10-Speed
Chain – Replaced
KMC X10e 10 Speed
Wheelset
XLC EVO Quick Release Hubs on Rodi FW Disc Rims
Tyres - Upgraded
Schwalbe Hans Dampf Evo MTB Tyre – SuperGravity 29
Handlebars
sDuro ePerformance Lowriser Alloy
Stem
sDuro Alu, A-Head 1 1/8" 31.8
Headset - Lower bearing Replaced
FSA no. 57, A-Head, semi-integrated
Seatpost – Upgraded to dropper post
RockShox Reverb Seatpost - Black / 420mm / 31.6mm / 125mm - MMX Right
Saddle
Selle Royal Sirio
Weight
22.5 kg
Electrical
Motor:
Yamaha Midmount 36 Volt, 250 Watt
Battery:
Yamaha Lithium Ionen 36 Volt, 400 Wh
Display:
Yamaha multifunctional display with operation unit
Range:
HIGH 280% - 70km STD 190% - 85km ECO 100% - 130km
Warranty
Commenced 14th January 2016
12 Months on components
24 months on electrical parts
5 years on frame
DSC_0060-001.JPGDSC_0063-001.JPGDSC_0067-001.JPGDSC_0071-001.JPGDSC_0075-001.JPGDSC_0080-001.JPGDSC_0081-001.JPGDSC_0082-001.JPGDSC_0084-001.JPG
Reactions: tisme
Emo Rider
659
414
Is this a 2015 model? The reason I ask is that 2016 models had four levels of assist (eco plus added). Has it ever had a dongle or modified to exceed 15.5mph? Reardless, the warranty, I do not believe it is transferable. Having said that, it is a good price.
James Woolfe
Dec 23, 2016
38
Hi there, this is indeed the 2016 model with 4 levels of assistance: Eco+, Eco, Standard and High.
It has never had a dongle or any other modifications (this could be verified by plugging it in at a service centre).
I'd be happy to answer any other questions / accommodate a test ride.
Thanks,
James
EddiePJ
4,632
4,012
Crowborough, East Sussex
www.facebook.com
I completely disagree.
If the bike has covered the claimed mileage of just 828 miles then it has had one hell of a hard life.
Look at the corrosion on the shock bolt, reverb bolt and fittings, headset bolt, seat post clamp bolt etc. Then look at the wear on the rubber handlebar grips, brake levers, pedal cranks and general rubbing and scuffs on the paintwork. The worst being cable rub below the seat post on the LH side.
My bike has had a hard life, and doesn't look this bad after about five thousand miles of use. Either Haibikes wear badly, which isn't so, or....
James Woolfe
Dec 23, 2016
38
EddiePJ - after 828 miles, some wear (e.g. Some Cable rub on a full suss) is to be expected. There is no corrosion on those bolts you mention. If you are not interested in the bike, maybe invest your time on a different thread.
Happy to take viewings / accommodate test rides to demonstrate the bike.
Thanks!
EddiePJ
4,632
4,012
www.facebook.com
I stand by all of my comments about the bike.
As for the corrosion, do you really want me to go through the photos that you have posted to highlight the corrosion, defects, and excessive wear and tear?
Even the front and rear wheel rims don't seemingly match.
I guess that one persons opinion of "good condition" does not match another persons, or certainly not mine.
One for starters.
D8ve
2,142
1,294
Bristol
Eddie 1 James 0
RobF
4,732
2,311
A different front wheel and 'upgraded' forks.
I expect the tree it hit came off better.
Reactions: Fordulike
Status
