Hello i will be building my own bike and bacically will be here for help so
With my electric bike i want to use lipos for the obvious weight advantages over pb
Bacically i want a 48v system so i think 2 4s batterys would do in series is this ok with lipos
Also as i want to add to my battery bank in terms of mAh can i paralell with lipos
Another thing with my alarm for low battery voltages and my volt metre to keep batterys over 20% would i just have all the balance plugs in series for each bank of 4s batterys (so 2 alarms etc)
With charging would an accucell 6 do (for each battery bank) and would that also be a case of simpally paralell all the balance plugs (for each bank)
Will be using 5000mAh 4s batterys will ask about manufacturer later
My motor is a 48v 15amp max brushed motor i suppose this is ok with this battery
HobbyKing Page not found.
Just to clarify i will only be charging in paralell and not the series
Many many thanks
Ben
Many many thanks
Ben
