Ok to start I have a new benelli city fold , and I've got all the new parts from psw power online, so all I've left on the bike was the battery and front wheel with the motor in it's a 250w and only has 3 wires from it , green yellow blue , no hall sensor wire, when I've put the new controller in and connected it to the kt-lcd3 the power comes on and shows all ok but when I press the throttle the display goes in to the error code 03- info , that means motor hall signal abnormality as to the instructions i got with it but is there a way of telling it there's no hall sensors connected ?
24V/36V 250W 6Mosfets 15A Brushless DC Torque Simulation Square Wave Controller.
This controller is sensorless controller, so just have three big cable for motor wire If you motor have 8pcs wires or 9pcs wires, you just connect the three big cable,also the motor can be run
This is the information from where I got the control unit
