Li-ion Charger recommendations
Robert Stanford
25
Hi,
Please can anyone recommend a reasonably priced quality charger for a 36v 20ah pack.
In an ideal world I would buy a Grin Technologies Satiator but they are pretty expensive.
There seem to be loads of cheap plastic chargers out there that I would not trust.
Ideally I am looking for a UK/EU supplier.
Thanks in advance,
Robert
KirstinS
3,224
899
Brighton
Hi,
Thanks in advance,
Robert
Hi Robert
I'm a tad confused by the post if i'm honest ! That grin product is designed for use with amyriad of different batteries and cells
It sounds like have just one? So just buy suitable charger
what's wrong a plastic casing per se? Used by tens of thousands without issue ?
Having said that faster chargers do tend to have larger metal cases and fans to remove heat
personally up to 2a seems fine in plastic and over that better with a fan
Take a look at BMS battery maybe. My 4a , metal case fan charger came from them
But fast charging reduces the life expectancy of the battery pack. Something to bear in mind .
I've been in this forum for quite a few years and standard plastic chargers are not something that generally goes wrong. It's pretty much everything else [emoji3]
KirstinS
3,224
899
Brighton
Worth stating that myself and wheeliepete are talking about same business (insat /bga reworking) !
Robert Stanford
25
Thank you both,
The reason that I am uncomfortable with the plastic case charger that I have is that the case gets up to 75 degrees C. It works perfectly and is really compact and lightweight to carry but I don't have any confidence in any device that appears to be running under that much stress.
My thinking is that a metal charger body will conduct heat and could be used as a heat sink. The addition of a fan reduces the stress on the components significantly.
Ideally, I'd like to be able to vary the voltage and the charge rate (down as well as up) 20ah allows me to charge to <90% for local trips and being able to charge at the occasional 3A would allow a boost at lunch time when touring.
My plastic charger could run for many hours without a problem or it could fail and catch fire or destroy the battery.
Maybe I'm over analysing?
Best regards,
Robert
wheeliepete
2,047
755
Devon
8,225
I modded my Sans Plastic chargers and they run a lot cooler now, I added about a dozen 8 - 10mm holes all over to aid airflow and cooling.
Robert Stanford
25
Those plastic chargers are designed to run hot, but I agree, it is a bit alarming how hot they do get. Some on here has modified them with taller feet an some venalation holes. Adjustable switching power supplies can be used as CCCV chargers and have the functions you want. These Gophert ones have a pretty good reputation.
https://www.ebay.co.uk/itm/DC-60V-5A-Precision-Compact-Adjustable-Digital-Switching-Power-Supply-110-220V/311068842937
Comes in 3 and 10 amp versions as well.
Thanks, I like the idea as it would also double up as a bench power supply. I haven't got my head around exactly what CCCV means. I am probably being a bit dim! Does it mean fixed voltage and limited current (i.e. 42V limited to <= XA)? If I use a power supply as a charger I assume that the battery will be charged when the current drops to 0A. I notice that my plastic charger is cooler as the battery nears full charge. I assume that this is because the current is tailing off.
Assuming that I have got this right (big assumption) I would use a power supply to charge my 36V pack by setting the output to 42V for 100% capacity and the current to the max I want to charge (nominally 2A). If I wanted to charge to 90% capacity I would set the voltage lower (e.g. 40V). Would I be right in thinking that the BMS balances the cells at the end of the charge cycle? If this is right not fully charging could cause balancing issues?
Sorry for my limited knowledge.
Robert
Robert Stanford
25
I modded my Sans Plastic chargers and they run a lot cooler now, I added about a dozen 12mm holes all over to aid airflow and cooling.
Thanks, how did you know where to drill the holes and how did you aviod damaging the internals when you drilled them?
Best regards,
Robert
8,225
4 screws to separate, remove rubber feet bungs to access.
I only drilled the top part with no electronics to prevent damage, two at each end either side of cable entry's for through venting and 6 - 8 on top exposing heat sink and 2 on the side.
You can also driil one the above the voltage regulator port to allow for voltage adjustment if needed.
8,225
Balancing in the main is about 41.5 - 41.8v depending on the bms software.
If not balance charging good cells should remain in check but also will be down to how well the battery has been welded/connected together.
A full charge every 4 - 6 uses should make sure all is well.
Robert Stanford
25
Brilliant, now I understand, my charger is welded/glued together which is why I was a bit confused.
Robert Stanford
25
Thanks, I guess the other alternative for local use is to charge fully but not re-charge until the remaining charge is too low for the next journey so I reduce the number of charge cycles and fully charge each time. Or I could do both :)
Benjahmin
2,480
1,691
69
West Wales
I'd say charge it and use it. The number of charging cycles quoted is full cycles, empty to full. Li-ion batteries don't suffer from partial charges, in fact may benefit because initial charge current is slightly lower and at a high for a shorter period. So anything 14 miles and above, I charge (14Ah battery).
16,442
no, don't do that.
Lithium ion batteries need to be charged at constant current first, then when the battery is 90%+ full, switch over to constant voltage to finish. The BMS rebalances the cell pack when the battery is 99% full.
Typically, Lithium Nickel Cobalt Aluminum Oxide cells need at least 4-6 hours for a full charge. You can charge faster but you will shorten the cell life. LiFePO4 can be fast charged in 2 hours.
If you want to build your own charger for a 36V battery, you need to program your PSU to be a current source between 31V and 40V with preset current to suit your battery chemistry and capacity (2A for 10AH). Then when the voltage reaches 40V, switch over to float voltage , to rise slowly from 40V to 42V in 1 hour.
Robert Stanford
25
no, don't do that.
Thank you,
That fits with the research I did this afternoon. I recon I am much better off with a good quality Li-ion charger at 2A than trying to use a power supply. I've read in a few places that the charger needs to be tailored to the battery (i.e. not all Li-Ion cells use the same charge profile) my current charger is 42V, 2A. Will any 42V 2A Li-Ion charger match the battery?
