I had an idea for this. I know everyone is skeptical (even me). There is at least one tradeoff though.
First you have one hub motor, in the style of flecc's Torq bike. I'm not sure what you could reasonably maximize top speed to, but let's say you do that.
The other hub motor on the other wheel (and this is key to strength), would be as small as possible, yet geared to only run about 6 mph (roughly a third of the Quando).
And that's the catch. You could climb probably any manmade road, not only without pedaling, but using very little battery energy (efficiency), because you're geared so extremely low but you also wouldn't move too fast.
And here's another trick for the engineers. Even on level ground the bike could start off with the first small hub motor up to 6mph, and then switch automatcally to the larger faster hub motor on all speeds above that.
So, essentially, you have a fast torg, with bottom end grunt and a little extra weight -- if you can do the tricky electrical shift between two motors somehow. You also need a small hub motor, maybe half the size and weight of the quando/torque to use, geared planetary-wise to work as described.
