Hi Frank as promised I have some answers for you from our battery guys.My concerns on Lithium batteries come from reading on this forum and in A to B magazine. They are:
I think this probably comes as a result of companies not specifying the correct type of lithium ion battery. All battery technologies such as Nickel Cadmium, Nickel Metal Hydride, Lead Acid and Lithium ion have product variants designed for high temperature, long cycle life, high rate discharge etc etc. Many Lithium Ion cell suppliers in China do not have their technology optimised for applications such as E-Bikes and therefore although their product may appear attractive on paper with good capacity, light weight etc etc the performance under high rate discharge is not so good and therefore they can have a high voltage drop under high load conditions. A correctly designed lithium battery should however be at least as good and perhaps even better at high rate discharge than all other battery types. The hybrid cathode material we use in our E-Bike batteries allows peak discharge at up to 5 times to rated capacity of the battery with very little voltage drop. Based on our 36V 10 Ah this means the cells can easily deliver 1800 Watts of power if needed. The limitation is therefore usually caused by the battery protection module as follows :1. Cut out on hills. Because the voltage of a lithium battery drops under loading, it can sometimes trigger a cutout. As peak loading occurs when you are going up a steep hill, it is pretty inconvenient. This seems to be more of a problem on higher powered bikes. People have reported it on Ezee bikes (and I think also on the Sparta Ion), but there have been no reports of this happening with Powacycles, where the much lower powered motor does not make such demands on the battery.
1. If the cell is not well suited to high rate discharge then the voltage can drop under load. It may therefore momentarily drop below the minimum voltage level of the protection module and the battery will as a result shut down thinking that the battery has reached the end of its discharge.
2. If the current limit of the battery is set too low or the motor wattage too high then under high rate discharge conditions the current demand from the motor can exceed the maximum current setting and again the battery will shut down to protect that battery and load.
Our battery has a max current limit on the battery protection module of 20A so in principle the battery can deliver 36V x 20A = 720 Watts.
It is hard to make a comparison without testing products under controlled conditions but it is widely acknowledged by cell manufacturers that lithium ion cells display better cycle performance and lower capacity losses under almost any condition. Again this assumes that the cell type used is suited to continuous charge and discharge characteristics of the E-Bike. As detailed before all batteries will lose capacity as a result of being charged and discharged this cannot be avoided but based on our standard specification then you should expect around 500 charge and discharge cycles and still have 70% of the original capacity. Given a daily commute of 5 days a week this should work out to around 2 years use before a significant loss of capacity is noticed. I can only assume that if many lithium ion users are reporting rapid capacity loss then the quality of the cells they are using must be very poor.2. Rapid loss of capacity and hence range with normal usage. People talk about losing anything from 10%-100% of capacity per year of life. The problems seem to arise if you use the battery to anything near its capacity (ie run it down past half charge). However, that is what I would want to do as I have a 25-mile return trip to work. NiMH by contrast seems to be much more robust. People on this forum report no loss of range after 2 years with deep discharges being possible.
You can only make a judgment based upon the specification supplied by the manufacturer and your belief in their figures.Therefore my questions are how can I be sure that a lithium battery would give satisfactory operating performance - ie ability to climb long hills without cutting out and ability to get me to work and back without having a very short life?
I do hope this helps
Best regards David
