These brake shoes that are in the drum are a bit like the car brake drums that they still often in use on the rear wheels. The usual treatment is to take them out and check if the lining material is worn out down to the metal shoes. That's unlikely though, but if very worn, best to order replacements.
Then clean out any brake dust from the drum, and to do that, take anti dust precautions, wear a face mask if possible. Use a vacuum cleaner hose to suck out the dust, and avoid breathing it in as it can be harmful.
Then a primary cause of squeal is a sharp leading edge on the lining material, so use a file to chamfer/bevel that so there's a smooth lead in on application of each shoe. That's it. Reassemble and try out. They will give an initial squeal as they bed in again, but should go quiet then.
