As far as I'm aware, I could do this by reducing the C5 setting on the lcd to a lower value, or by crimping the shunt on the controller.How do you intend on running a 35a controller output to only draw 20a ?
You said the controller was warm, that rules out thermal cutoff.As far as I'm aware, I could do this by reducing the C5 setting on the lcd to a lower value, or by crimping the shunt on the controller.
Do you know if it is possible for a controller to momentarily cut a high current due to something other than thermal cutoff?You said the controller was warm, that rules out thermal cutoff.
We need to know if the battery sags before you make any rash decisions.
C5 can only go down to -1.5 IIRC which would be 23 A with a 35A controller.
No, if you feed too many volts the capacitor will blow other than that they are pretty bullet proof.Do you know if it is possible for a controller to cut a high current due to something other than thermal cutoff?
I suppose you're right that I need to check if the battery is sagging before I make any other decisions. I'll take a look at the voltage next time I ride up the hills.
The battery can be supplying the tiny amount of current required for the LCD. Some LCDs have a battery so are self powered.I just have one more question: If the problem was being caused by the battery, would it be expected that the LCD would shut off rather than stay on? It would seem to me that the fact that the LCD stays on while power is being cut indicates that the issue is being caused by the controller.
It depends on the software version I think.Yeah I use pedal assist most of the time. I just use the throttle from standstill.
I'll reduce the C5 setting to number 8 and see if that stops the problem.
Are you sure that the C5 setting goes down 0.5a from one level to the next? On the kt-lcd3 manual that can be found online, it says that the C5 setting goes down as a percentage. According to that manual, the C5=9 level should provide 91% of the current that C5=10 provides, and C5=8 should provide 87% of the C5=10 current.
Try all C5 settings down to 0.Yeah I use pedal assist most of the time. I just use the throttle from standstill.
