I started the conversion today. This one will have one or more novel features. which I'm still trying to work out, so might be a bit slower than what I normally do. I snagged the bike for £380 and the kit cost about £500 including batteries, so I'm hoping to keep the total to less than £1000.
I bought this one because it's one of the few full-suspension bikes that can accommodate the 12aH LiFePO4 Headway battery in the frame triangle.
It's almost a shame to butcher this bike because it's so nice as it is. Everything about it is real quality, but I bought it for my project so here goes.
First I tried the Q100 36v 201 rpm motors in the wheels. The rear went in, but the 10mm axle wouldn't fit in the 9mm drop-outs on the Rockshox Reba forks, so out with the dremmel to widen the front dropouts, and I deepened front and rear by 1mm to centralise the axles.
The front wheel was central, but the rear was off-set
so out with my spoke key and after half-hour it was central.
The ant-rotation washers are as good as useless. the tabs just float in mid air, so I smashed one flat and then cut a piece of steel an exact fit and welded it on to make an extension as a torque arm.
