SCOTT ELECTRIC MOUNTAIN BIKE **SOLD**
lanerboy
43
55
midlands
I am selling my Scott electric mountain bike due to a change of circumstances, I have fitted a Oxydrive 350 watt rear wheel drive kit to this bike and it has only done 19 miles yes it really has 19 miles only on the Oxydrive kit.
The bike itself has done around 500 miles all road work I have the original rear wheel to slip back in to convert back to a normal mtb, the Oxydrive wheel has a brand new rear cog fitted, I have fitted a adjustable stem for the bars so they can be set higher if required and the forks have the quick release lockout button on the handlebars, if you are looking at this then you probably know all the specs but I will try and answer any question you may have
This 350 watt kit will do 20mph (on private land off course) I have not fitted either brake levers or the throttle but they will be supplied with the bike still in the box brand new.
This is a brilliant bike for both off road or commuting
Price is £999 sorry no offers
Please reply or PM for more info, the bike is located in Burton On Trent in the Midlands
20161224_111500.jpg20161224_111331.jpg20161224_111424.jpg20161224_111430.jpg20161224_111517.jpg20161224_111554.jpg20161224_111304.jpg
8,173
Rear axle needs rotating 180 degrees ideally so that the cable forms a drip loop, other wise any water will track down the wire and into the hub casing causing problems eventually.
