Self sealing inner tube saves the day :)
Fordulike
3,802
1,537
Out on a ride today, I was aware of an unusual sound which presented itself on every revolution of the rear wheel.
On closer inspection, I noticed a stick on the tyre that was hitting the mudguard.
Thinking it was stuck on with the mud on the tyre, I stupidly pulled at it and the next thing I knew, pssssssst.
Bugger, it had actually gone through the Schwalbe Marathon tyre and punctured the inner tube too.
Luckily, the escaping air stopped after about 5 seconds and the tyre was sealed for the journey home at least :)
I've thoroughly checked the tyre and I think the foreign object has been totally removed. The tyre has been pumped back up to my regular pressure and I will check it in the morning to see if it has leaked at all.
If it hasn't leaked any more air, is it ok to just to leave it as it is, or would it be best to replace the inner tube?
Anyone's experience of carrying on using a punctured self sealing inner tube, will be much appreciated.
kangooroo
268
183
Wye Valley
I think the general advice is to replace the inner tube.
That said... on my first outing on my first e-Bike, I rode straight over a piece of blackthorn and the thorn went straight through the tyre, puncturing the inner tube. I saw what had happened and managed to break off the twig leaving the thorn embedded inside the inner tube and it lasted for my 4 mile ride home (phew!).
The next day my delivery of Slime arrived so I removed the thorn, deflating the tube in the process, pumped in the slime, spun the tyre several times and it held. This was August 2015 and the same inner tube is still in situ and the repair has held.
Fordulike
3,802
1,537
That's encouraging as it's a slime filled tube that's on there :)
jdallan
306
163
I posted recently about a very similar incident involving punctures from hawthorn trimmings. Fortunately my tube was "slimed" so I made the 5 mile run home without having to tackle a repair with arthritic fingers in the encroaching darkness. It transpired that there were three separate punctures so I replaced and re-slimed the tube.
Jim
Fordulike
3,802
1,537
It goes to show, Schwalbe Marathons plus slime tubes, really do make a great partnership.
If the tyre pressure hasn't dropped by tomorrow, then I'm just going to leave things be.
oldtom
These reports on the efficacy of the slime product are causing me to lean towards using it in my tubes regardless of the fact I have MPs front and back. My reason is simply that I just can't be bothered with all the aggravation of mending a puncture at the road side, especially in winter.
Cost-wise, it's not exactly a high price to pay for saving the aggravation and unlike a tubeless car tyre, it can still be repaired and re-used - try asking Kwik-Fit to do a repair on a slimed tyre! I bet the guys with tubeless bicycle tyres don't scrap them when they get a puncture in a slimed tyre.
Tom
6,319
Fordulike
3,802
1,537
Woooo, the tyre held pressure overnight and on return from a 15 mile ride.
Marathon Plus tyres and slime tubes must come a very close second to tubeless tyres. This combo is definitely worth considering if you need reliable puncture protection.
Still worth taking a mini pump along too though, as you do lose a bit of pressure until the sealant works its magic.
Benjahmin
2,483
1,696
69
West Wales
Thanks, think I'll investigate this some more 'cos we're coming up to hedge flaying season and there'll be crap all over the lanes. They are, of course, supposed to clear it all up. Yeh right:p
Fordulike
3,802
1,537
Blimey! I run my wheelbarrow at 30-35psi. It sounds a bit draggy to me on 28" rims but if you have experimented a bit and find 35psi adequate, I may give it a try.
Thanks for that,
Tom
Mine's got a lot of torque, so I don't notice any drag.
Reactions: IR772
5,785
I have never run tires over 43 PSI!
Reactions: Fordulike
Benjahmin
2,483
1,696
69
West Wales
Crikey, really? I run my Marathon +'s at 55, feels squidgy otherwise.
On the slime tube front, seems that 700c tubes with schrader valves are a bit of a rareity.
Fordulike
3,802
1,537
Most of my riding is on woodland trails, so I inflate the tyres for grip rather than rolling resistance. There's no squidgy feeling, although I could imagine they would feel like this if ridden totally on hard surfaces.
Benjahmin
2,483
1,696
69
West Wales
Gotcha. My riding's on tarmac although that's an approximate description on a lot of the smaller lanes around here .
