Sense Check on Bosch Battery Charging
GeniusBike
UK
Hi Everyone,
3 weeks into E-biking and I think I have an issue with my battery charging. Can you help me sense check if there is an issue?
Battery = Bosch Powerpack 500
I plugged it in this morning to charge with the standard Bosch charger. The battery indicator light's on the battery illuminate however ...... on previous charging im sure the lights would flash, they are currently solid at 3 bars and after a few hours charging are not budging.
Can anyone confirm:
  1. Battery indicator lights should flash to indicate charging?
  2. How I'd check if the charger is faulty (other than testing on another battery)?
Any help would be appreciated, even if it's just to tell me I'm thick :)
GLJoe
852
407
UK
Hi Everyone,
Can anyone confirm:
Check there is actually power getting to the CHARGER.
I'm not 100% certain on this, but I think if the charger is plugged into the bike but is not switched on, the lights come on as you've described.
Check plug fuses etc.
Cheers
GeniusBike
UK
I swapped over the fuses this morning. Didn't have any effect. Indicator lights are on but the battery doesn't seem to be charging. :-(
Croxden
2,134
1,384
North Staffs
Tell us your approximate location and see if there is anyone close with a Bosch bike so you can try each other battery and charger.
GeniusBike
UK
I'm in East Manchester near the Etihad stadium.
I've just run a multi-meter on the charger and it's out-put voltage is zero indicating the it's broken.
chris_n
656
399
Niedeau, Austria
Not necessarily, it could be waiting for a signal from the battery before turning on. This would eliminate sparking when you plugged it in.
GeniusBike
UK
I've just taken the battery and bike to a bosch service centre.
The charger is working and charged another battery they had in the shop.
They can run a diagnostic on the battery but only when it's attached to the bike. I'll be taking it back on Monday. Not looking good for a battery that's done less than 500k.
12,253
73
Couple of points.
1. The output voltage from the charger to the battery is zero until the charger is powered up and a contact has been made with the battery. The Bosch has extra contacts for this communication.
2. The green lights on the side of the battery pack blink as the battery charges and eventually all 5 should become solid green and then extinguish when the battery is fully charged. I am assuming that the electronics is measuring the charging current, and when it falls below a certain amount, the lights stop blinking. If your battery was becoming defective, then that might occur at a lower overall charge.
3. If you were to charge the battery while it is on the bike, using the connector built into the battery cradle, the state of charge will appear on the activia display.
4. 500k???? How could you do that after 3 weeks ? Or is the bike from a previous owner? Miles or km? . The 500 whr battery is recent. Is this a mistake or typo. ?. If it were truely miles, Bosch might want to put that battery in their hall of fame having thought about this number a bit more .. is it actually 500 km r about 300 miles , which would be reasonable for a three week ownership
panorama.bikes
Feb 7, 2020
Have the same problem. What was the solution?
peter chapman
18
49
just had this issue brand new bike only second charge of the battery bike only done 16 miles, battery won't charge no leds light up. not the sort of reliability you would expect from a bosch unit.
Kresimir Piricki
Mar 19, 2018
London
Hi Everyone,
Can anyone confirm:
I had this issue also. When I put the battery back on the bike and turned it on and off with intuvia, and then again took it off and connected to a charger, it was charging OK.
