I followed the very useful instructions for Torq front tyre change & its now done .
When replacing the front wheel a the end, I realised I hadn't noted where the (looks like) washer & spacer go on the left, non-wired side of the axle (sorry if it seems trivial, but I'm a bit of a novice with these things and wouldn't want to put it back incorrectly): I have 2 - a small metal washer-like ring ~1mm thick with a radial "slit" & not quite flat, plus a brassy 3mm thick spacer-like ring. The forks don't seem to require a spacer inside the dropout between them & the nut on the motor, but I also seem to recall that the thicker brassy ring was inside the thinner metal washer and can't see why the two should be outside the fork dropout, between fork & outer wheel nut??
Please can anyone advise where they go?!
At least everything else went ok & motor still works .
Stuart.
Stuart.
