Torque and gears and design limits. How to calculate ?
KirstinS
3,224
899
Brighton
I have tried to search web but not doing a good job. Any help appreciated . Another kiwi I think has a particularly good understanding based on previous posts
Basically I have an alfine 8 hub and a bbs02b. And currently a 16t rear sprocket and a 42t bling ring up front
How on earth do I calculate wether I’m over stressing the alfine (at least to design spec , we all know it’s over designed and near bullet proof)
The settings on my bbs rarely pull as much as 500w. So less than a bbs01 at full tilt (around 600w)
But I’d like to know as my mates dad owns huge chunks of Essex . So private , unrestricted madness would be legal. As long as I go back to normal settings before I use it again
Just don’t want to blow up my alfine ....
8,219
I not 100% but even with power drive it is down to gearing that determines any failure 42 /16 combo is well under gearing stress level, 2.1 is recommended so 42/21 would work.
http://www.gear-calculator.com/
But doesn't allow for motor power.
Over to you AK :).
5,785
:) I'm going to have to change my reading habits!
Shimano recommends 19, 20, or 21 for a 42 tooth chain wheel. So 16 is fine, 22 and above are no-no. Tech notice is on their site.
KirstinS
3,224
899
Brighton
Thanks , but isn’t it something to do with the watts that go through any given ratio ?
5,785
It is the torque that the gearbox can handle. Or rather the torque it can't handle so 42:16 will have less torque than 42:22 throughout the 8 speeds.
8,219
I read somewhere that they generally are over engineered and watt wise they can handle 1500w which none of us can do even standing on the pedals.
As already mentioned K it is torque that kills them via wrong gearing. 2:1 ratio or more is recommended so for a 42t front use a max 21t sprocket.
I have just put my old BBS01 from 2013 on my ht mtb with alfine 8 and have fitted a 48/32t double up front, chain line is a bit crap and front changes up and own ok without any issues so am going to give it ago.
With the 32t gearing torque will be a bit high with a 20t sprocket currently fitted though I have had no issues previously with this set up using a front hub motor, the 32t I only used occasionally.
Alfine 8 ratios 0.527, 0.644, 0.748, 0.851, 1.000, 1.223, 1.419, 1.615
Divide sprocket T size by each ratio above to get prexact gear size equivalent.
Sprocket size to approx. cassette gearing.
16t = 10/30 10,11,13,16,19,21,25,30.
18t = 11/34 11,13,15,18,20,24,26,32.
19t = 12/36 12,13,16,19,22,25,30,36.
20t = 12/38 12,14,16,20,24,27,31,38.
21t = 13/40 13,15,17,21,25,28,33,40
Trevormonty
1,135
564
17
NZ
Don't be surprised if hub dies.
KirstinS
3,224
899
Brighton
Ahh
I think the penny has finally dropped ! Thanks for the full and patient explanation !
5,785
I really wanted a nexus 8 (Alfine without disk mount) and the only way I could work it was with a twin chainwheel:
- low geared one right on the limit specified by Shimano for the local "hills"
- high geared one for flat going
And more number crunching made me come to the conclusion that the Rohloff was the best answer to this problem...
KirstinS
3,224
899
Brighton
Without question ! It’s something I’ve always hankered after but it’s a bit out of financial range more me
One day though !
