Torque
Andy1865
289
15
Good evening all, does anybody know what torque i would get from a 500watt rear wheel motor with a 36volt battery and a 30amp controller. Thank you.
BG bicycle
99
17
Bulgaria
Genuine 500 watt motor? Or one disguised as 500w, but is actually a 1000w motor.
What ampere is your battery?
I run 10s 13p on a 1000w motor guised as a 500w. Slow on hills 28kmh. If that helps.
Andy1865
289
15
Afternoon BG, my battery thats on my Freego Hawk is 36v and 15.6Ah. Its a Cyclotricity 250/500watt rear wheel kit that im having fitted so its an upgrade on my current 250watt motor. Sorry i dont know anymore then that. The company thats fitting it, is useing my current battery. Thanks. Andy.
Andy1865
289
15
The battery itself is a Samsung cells
BG bicycle
99
17
Bulgaria
Hello Andy1865. All the best on your build. Good quality cells make the difference the bigger motor and battery make a huge difference when upon an incline.
30,349
It's a Direct Drive hub motor so will have fairly low torque though high speed.
It may well have no more or even less torque than your original Freego Hawk motor, just a speed gain.
BG bicycle
99
17
Bulgaria
I ride on a 4t direct drive hub, the hub is capable of 48volt, 52v without concern, without specific knowledge of a motor... However, Samsung cells are good quality and again depends on specifics, performance, etc.
16,387
Reactions: BG bicycle
