Hi all,
My first post on here is a plea for help! I have recently caught the ebike "bug" after buying a Raleigh Dover panasonic crank drive bike for my wife and trying it myself. Fantastic machine!
I bought myself a much used and filthy dirty Torq 2 a couple of months ago (spent all the money on the Raleigh!) and have restored it to an almost new condition with invaluable assistance from Fleccs Torq site, this forum and Cyclezee. I am very pleased with it, completely different from the Raleigh, but a very good bike.
In my new capacity of "expert" (I dont think!!! )I have now been asked to help out a friend who has inherited a 15 month old Claude Butler Glide 2, which has a 36v Bafang SWXB front hub motor, complete with hall sensors. After the demise of the original owner, the bike was left half in /half out of a shed for months, and although the handlebar module /controller lit up, and the battery is fine, the bike would not run.
It is essentially a pedelec with 6 levels of assist provided by the throttle, but has a "launch control" mode to 4 mph, so the motor can be run without the need to turn the pedal when testing. When I tried to operate this, the motor would make a soft "click" and then nothing. Testing the motor phase wires showed a rise to 10.6 volts, then drop back to 5volts on one of the wires when I operated the throttle.
I tested all the wiring for continuity, and tested all the usual suspects (brake cut outs,etc) for problems, but all seems well.
I decided to take the motor apart, which I believe has got to the root cause of the problem. The unit leaked brown water from the axle when I took the wheel off, and there was plenty more inside when I separated the motor from the casing. The SWXB unit has six screws holding the side panel, so no special tools required as such, just a bit of gentle persuasion. The gears and housing were in a sorry state, but I cleaned everything up, freed off the gears, re greased and reassembled the unit. Launch control tried again, and the motor turned, very slowly at first then slightly jerkily, nowhere near the right speed but at least turning.
So if I am right in distilling down all the collective wisdom on this site, the likely problem is the Hall sensors have burned out or become water damaged. I am more than happy to have a go at replacing them ( and have traced the sagas of a couple of members who have done the same thing) but I am now stuck on a mechanical rather than electrical point.
Does anyone know how the side plate, which is spinning freely in its bearing, is fixed on the axle? And how it is removed? I dont want to force it unneccesarily as its only a piece of aluminium, but without removing it I cannot get to the sensors.
I know that it could maybe got up and running using a sensorless controller, but the current controller is linked to the handlebar module which is a combined battery meter, assist level control, launch control, and cycle computer all in one, so we would like to be able to keep all those functions if possible.
I just need to get the side cover off the axle for starters!
Any help most gratefully received.
Mark
Mark
