What can I do to stop the BBSO1 dropping the chain on some gears?
Discussion in 'Electric Bike Conversion Kits' started by flik9999, Mar 4, 2018.
  1. flik9999
    flik9999 Finding my (electric) wheels
    Dec 11, 2016
    154
    7
    london
    Hey so I have the BBSO1 installed on a bike that has an 8 speed cassette 11-32 (11,13,15,18,21,25,28, 32). However the chain occasionally drops mostly when in the climbing gears (28,32). What do I need to install to stop this happening.
    I have already tried putting a front derailer back on that is locked into position but that didnt work. Can I install a narrow-wide chainring as it is or would I need to buy an adapter first and would this work or is there more that I need to do to stop the chain dropping off the chainring.
    I found this chain holder will this work? https://www.evanscycles.com/hoy-pin...nlASQN0SbOwfN-cfBU754Xp_WfqvMpLBoCga8QAvD_BwE
    #1 flik9999, Mar 4, 2018
  2. anotherkiwi
    anotherkiwi Pedelecer
    Jan 26, 2015
    6,115
    1,741
    It drops to the inside I presume? My GSM does that too when i change gears on really bumpy terrain. The problem is less serious for me because I have a double chainwheel so the chain drops from the big ring onto the small one and I often don't notice until I change up again on the flat.
    The chain guide you show is a good option.
    Stop hovering to collapse... Click to collapse... Hover to expand... Click to expand...
  3. Fordulike
    Fordulike Pedelecer
    Feb 26, 2010
    3,229
    735
    Tyne and Wear
    I'm running an 8 speed that had exactly the same issues as yourself. The cure for me was to fit an offset chainring to improve the chainline. Originally used an Alcedo Italia 42T and now a Bling Ring 42T.
    I also refitted the front derailleur and locked it as you have done, plus shortened the chain by a few links to allow good chain tension across all 8 gears.
    Haven't had a single chain drop, where as before I was dropping constantly in the first two lowest gears.
    • Like Like x 1
  4. Gagsinio
    Gagsinio Finding my (electric) wheels
    May 9, 2015
    42
    I have a BBSHD, which originally threw the chain off and would only let me use the middle cog and smallest on a 9 speed cassette. Changed the cassette and chain, now can use every gear, have a gear sensor, which turns the motor off momentarily (bit like a clutch), makes gear changes much better, no crunch.
  5. DynatechFan
    DynatechFan Pedelecer
    Oct 20, 2017
    166
    25
    t'North
    flikk9999 what is your chainline like - it sounds like the chainset is on a BB that is too long. What quality / speed chain are you running?
  6. Steve UKLSRA
    Steve UKLSRA Pedelecer
    Oct 29, 2015
    318
    202
    Porthmadog
    We run 104BCD adaptors, NW chainrings (using 10sp), clutched derailleur and a chain guide and have never had a chain drop on any of our bikes (we run red and black trails), even on the 72mm BBs with a non-mechanically-sympathetic chainline.
  7. Gagsinio
    May 9, 2015
    42
    New chain is a Wipperman connex 808 and rear cassette is a Shimano CS-HG41, works how it should now.
  8. whiteturbo
    whiteturbo Finding my (electric) wheels
    Jul 22, 2016
    94
    Bristol UK
    Simple! get a Lekkie Bling Ring, first its a narrow wide ring so the chain sits nice and deep, second it moves your chain line inboard.Since fitting the Bling Ring i have had zero chain drops.Expensive(£75) but worth every penny.
  9. Fordulike
    Fordulike Pedelecer
    Feb 26, 2010
    3,229
    735
    Tyne and Wear
    Definitely. Quite surprised that Bafang didn't start churning out something similar as standard with the kits.
  10. anotherkiwi
    Jan 26, 2015
    6,115
    1,741
    Lack of imagination... Or penny pinching.
    Better still they could have delivered the motor with a spider that would allow mounting of one or two standard chainwheels. A spider designed to provide a standard chainline...
  11. whiteturbo
    Jul 22, 2016
    94
    Bristol UK
    @anotherkiwi best idea yet, a spider with a 9mm offset would be good, surprised no one makes one , would make a fortune selling at about a tenner so you could fit any narrow wide chainring because that Bling Ring is way overpriced.
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    By continuing to use this site, you are consenting to our use of cookies.
    Dismiss Notice
