Where to get 160 cranks
Russelliow
95
15
35
iom
I'm looking for some 160 mm cranks for my Bosch powered KTM but I'm struggling to find any. Any ideas where to try?
Cheers
Russell
Sent from my TA-1033 using Tapatalk
16,387
Gringo
1,333
835
Northampton
A few options here ( I don't know about the "Q" factor required)
http://www.trialsaddict.com/cranks/isis-cranks/jitsie-isis-cranks.html
https://activesport.co/epages/80c85f8f-7a95-4b1c-9c30-e64b314f3f2e.sf/en_GB/?ObjectID=50432&ViewAction=FacetedSearchProducts&SearchString=Chainset+160mm
I chose to buy a set of taps and re-tap my existing crank arms, originally 170mm and now 150 (20mm being a safe distance between new & old holes)
In this pic I have a short spindle fitted at 150mm.
As I mentioned in a similar post
It's worth noting, as you shorten the crank arm your pedals get further from the ground and you'll need to raise the saddle higher to maintain a decent leg extension then you'll find it harder to get your foot down
5,785
Russelliow
95
15
35
iom
Ok thanks I will give them a call tomorrow. There should be plenty of seat post left if I have to put it up a bit but I run it pretty low anyway.
flash
189
78
68
CW12 Congleton
grldtnr
627
288
south east Essex
Cheers
Russell
St. John Street cycles ,of Bridgewater , might be a supplier, Google ST.JOHN STREET CYCLES.
They are good for sourcing unusual or hard to get obselete parts.
Good service too!
Reactions: Barrio Barranco
Russelliow
95
15
35
iom
Well I have ordered some trials bike 160 mm cranks from trials addict so I'll see how they go. I can only see 152mm cranks on the Miranda site and I think they could be a bit short. I read an article about ebike cranks and they said 160 seem the same but 150 are a bit short.
Russelliow
95
15
35
iom
Well they were delivered in a super speedy time but they don't fit. Will try and order some KTM cranks next week.
Gringo
1,333
835
Northampton
but they don't fit.
Don't fit how ?
Bosch use ISIS Drive ( International Splined Interface Standard )
As the name implies ISIS is a global standard fitment so any ISIS crankarm should fit any ISIS bottom bracket.
Russelliow
95
15
35
iom
Don't fit how ?
The spline fits but the out side is too fat and it touches the motor housing on both sides where the crank arm sits just inside the sproket shaft .Also it looked like the crank might come in to contact with the actual motor because it didn't bend out enough.
Gringo
1,333
835
Northampton
Thanks for enlightening me.
The internet is great for sourcing components but can get infuriating trying to find full specifications whilst mixing and matching parts, the "Q" factor being a good example.
Better luck with your next choice
5,785
Russelliow
95
15
35
iom
Well I've finally fitted my 152mm KTM cranks and it's much better. I don't think you can put down as much power but i have a lot more confidence pedaling and turning slightly .
