I'm not sure if my bike is 'behaving' as it should (or maybe it's me not understanding it!!!). Sometimes if I've got assist set at 3 or 4, it will be on no assist for a while because I'm on a fairly flat bit of road (which is what I'd expect) and then it suddenly jumps up to the top (full assist) when the road goes up a very slight incline. Does this seem correct? This only happens occasionally. Usually it just goes up one notch gradually, depending on the assist needed, not from one bar to full assist in one movement. I'm wondering if I've got a problem.
Another thing I noticed today was that assist was set at 3 bars and it suddenly jumped up to 4 going up a slight incline - no throttle. Should it jump up higher than you've got it set?
