18650 charger and also case recommends pls
spanos
244
64
Hi all
can anyone recommend a 2 or 4 x 18650 cell charger ? Market is flooded and I’d prefer tried and tested quality on my nice cells ! I’ve bought cheap before and regretted it.
also can anyone locate a 2 x 18650 battery pack /container for running 8.4v dc lights ? I can find millions of 4x and 6x and plenty that are shrink wrapped ready made. I want to use my own cells
any help appreciated as ever
cheers all
3,986
I use one of these. It has a lot of extra functions for testing them, which is useful for building ebike batteries, but probably a bit over specified for charging lights.
I've used the really cheap ones before for my light batteries. One packed up, so I had to get a replacement. I've never been sure about what happens if the batteries are at different voltages, so I always do one at a time.
I think a charger that has two completely independent channels would be better.
Reactions: KirstinS
6,314
the reason there 4 cell packs is because you need 2 cells to make the 8.4v and the other two are for capacity.
you can charge the cells in the pack but it does not balance the cells very well why i use the above charger.
there is also no short protection so make sure the cells are in the right way.
Reactions: trevor brooker
Benjahmin
2,478
1,691
69
West Wales
I have the nitecore charger, it is really good. Does AA's and AAA's into the bargain. Charges each cell seperately so balancing them.
Reactions: KirstinS
KirstinS
3,224
899
Brighton
The top one looks like the ticket. Thanks
KirstinS
3,224
899
Brighton
Thanks SW. Yes I have the same case in 4 and 6 cell versions. I have a handful of 30q cells sitting unused and 3ah of 8.4V is enough for me 90% of the time. Was hoping to find a sleeker 2 cell cze but guess they dont make them
3,986
Hi all
cheers all
Just a warning. Your lights are more likely to damage the cells than the charger. If your that worried about them, fit a voltmeter.
