20" rear motor for kids ebike.
Trevormonty
1,135
564
17
NZ
Friend wants to fit kit to 20" kids bike. Any advice or recommendations on following would be appreciated.
After light rear 250w 36v motor or better wheel.
Low weight is more important than power as kid is light plus torque advantage of 20" wheel. Needs to handle Shimano 10spd cassette.
Also need controller that can be program for consist current/power output. Plan is to have 3-4 power settings. A handle bar switch with Up Down.
Cutoff for hydraulic brakes.
Plan to use a couple of 18V drill batteries, being builder has few spares. A couple 3A should keep weight down.
2,673
Don't forget eBikes are only legal for children of 14 or over.
wheeliepete
2,047
755
Devon
BMS Battery do this small motor that will take a cassette. More than enough power for a kids build. Only 2.1 kg. Go for the high speed (328 rpm) to suit a 20" wheel. Rated at 350 watt, but it's only written on a sticker, which falls off very easily;)
https://bmsbattery.com/ebike-kit/618-q100c-cst-36v350w-rear-driving-ebike-hub-motor-ebike-kit.html
This controller can be power/speed limited from the LCD.
https://bmsbattery.com/controller/827-s-ku65-250w15a-6mosfets-controller-without-led810.html
https://bmsbattery.com/parts/670-s-lcd3-lcd-meter-for-s-series-controlers-ebike-kit.html
PAS sensor and throttle in parts section.
Trevormonty
1,135
564
17
NZ
Thanks Wheeliepete.
As for being legal, we are in NZ so not sure of law regarding kids and ebikes. Need to investigate that.
awol
1,216
374
Reactions: wheeliepete
wheeliepete
2,047
755
Devon
I thought the Xiongda would be a good choice too, but OP wanted a hub to take a 10 speed cassette, although I'm not certain 10 speed would fit a kids bike frame.
awol
1,216
374
I missed the 10spd cassette requirement, your Q100C 328rpm is probably a more suitable option for that.
