With all the talk of illegal / legal bikes recently I thought I'd try and setup my Alien GSII so peak power fell in line with the EN15194 regs.
Really this was just an exercise to see what a lower powered bike would feel like.
The E-Crazyman controller I have retro fitted to the bike is programmable, I can set various functions including battery and phase current, however, there are certain limitations in the s/w which meant the phase current would have to remain at the same level I normally use IE: 35 amp
But I can program the battery current down to 7amps. Current control in these controllers is somewhat crude and can be as much as 5amps out, my controller I found is +3amps out, so 7amp programmed means 10amp in reality.
Still it was enough to get a feel for a low power setting. Working backwards the EN regs allow +10% on motor power so 275w.
Motor speed where peak current is drawn corresponds to about half the no-load speed and looking at the ebikes.ca simulator for geared motors I took a guess and estimated efficiency of the motor to be 65~70%.
Losses due to wiring and controller resistance are hard to quantify but at these low currents it would not be too much so I guessed at 20w. So a couple of gross assumptions made.
Taking 65% efficiency, 275w would require 423w in plus 20w for losses gives an input of 443w....call it 450w.
At 36v this meant I needed to set the controller to 12.5amp or in my case due to the +3 overshoot 9.5amp.
On the road I noticed the motor was quieter and speed the same. I picked out a few hills steepest about 10% and the bike seemed to climb just fine at about 8mph.
Checking the Watts Up meter it recorded a peak of 12.3amps and 478w so motor power was probably around ~300w or maybe higher....it didn't seem too bad and could be a good compromise setting between distance and assistance on hills.
I then decided to reduce power further and set 7amps on the controller (10amp real) and tried again. Peak amps recorded where 9.7 and peak watts 390 so at a guess the motor was running at 240~250w.
This was noticeable but the bike was still ridable, pulling away I initially thought something was wrong as the motor was very quiet but it was still working! Acceleration was noticeably slower but the bike still climbed the hill albeit at 6mph this time not 8mph.
No idea what the range would be with these settings but I've set the controller back to 12.5amps and intend to try it one weekend.
