42v charger only 37v output?????
Kristoffer P
46
Denmark
Hello from Denmark, what is wrong with my cyclotricity bottle batt kit. Almost new 2 happy months and not sending it back because i need to learn this emagic. Power went down to 37 v over a few days and the 10 cell groups were reading okay. Then replaced bms and that did NOT help my charging problems. Why the h..ll ar my charger only putting out 36.9 volts and not the 42 v it says on back.? Bourght one new charger and messured that to 36.9 v also before changing bms. I kinda feel like i need 42 volts comming in to my battery chargong port. The charger shows charging up to 36.9 v and then stops. What is going on? I really enjoy my ebike but this drives me a little nuts.
17,204
recheck the setting of your Volt meter. If you select AC instead of DC, you'll get a wrong reading.
Check also the output voltage of youur battery against the number of bars on your LCD to confirm the reading on your voltmeter.
Kristoffer P
46
Denmark
DC is on and output reads 36.9 volts on the discharge connectors underneath the battery. Led also shows nothing at this stage.
8,746
Can you confirm with a new voltage reading the charger output with it plugged in the wall but not to the battery please.
The charger as you say should read 42v when plugged in to the mains if not then the charger might be faulty but first try a new battery in your volt meter.
17,204
check the voltage display on your LCD.
37V should show as 3 bars on a 5 bar display.
if the voltage on your LCD shows full (5 out of 5) then you need to replace the battery in your voltmeter.
Kristoffer P
46
Denmark
I will try with a fluke voltmeter at work tomorrow.
8,746
Kristoffer P
46
Denmark
I only have led indicators, 4 pcs, no lcd display. And 37 volts is below 1 pcs.
Kristoffer P
46
Denmark
OMG my voltmeter was faulty by almost 5 volts!! Charger output 41.7 messured at work and i belive my battery must be the same when i arrive home to controll it.
What a nice way to learn about ebikes:confused:
Now if i only had a spare controller. ....
Reactions: Nealh
8,746
Your meter may be out because it needs a new battery if that is not the answer get a ne meter, make sure it is one with continuity buzzer for wire/ circuit fault finding.
It did appear a strange scenario that 2 new chargers were thought faulty.
When you get strange results/readings it's always worth checking with a different meter so always handy to have two different models/brands as they are cheap to buy.
8,746
If it's KT then they are easy to get hold of from China, via PSWPower/Elifebike , BMSBattery or Aliexpress.
Kristoffer P
46
Denmark
Well it was the cable from controller to display that was broken inside, 3 months old and no signs of wear at all. It really was not easy to find that fault at all.
Cyclotricity replased it and i must say that they respondet quickly to my emails and they did what any consumer would like a shop to do when a product fails. Thanks cyclotricity. Bike running strong again.
Reactions: robdon
