Air pressure in front forks
ladymelchet
19
Hi there
I have a 2022 Cube Kathmandu Pro - just having issues with what air pressure is needed for the front forks in PSI or bar? Bike is being used for mainly leisure cycling roads and cycle paths. Thanks
AndyBike
1,700
728
Find your weight(inc riding kit) in Kg. Check chart, and use a high pressure pump (not a standard bicycle pump)to get the approximate pressure. Obviously less pressure will make it a bit more bouncy.
