hi all i have had an ongoing problem with my alien special e-bike the problem is with the battery when you switch it on the three power lights come on but when the throttle is operated or the pedlec the motor does not respond the green and amber lights flash ,you can hear the power in the motor when it is lifted off the ground the motor turn very slowly but thats it ,alien sent me a new battery in may and this cured the problem but now three months later the new one has got the same problem (the old one was 3 months old to) any come across this problem before?
Two dodgy batteries on a trot is a bit too much of a coincidence for my way of thinking.
Assuming you are still using the original charger, this may be the common denominator and needs to be checked first. I suggest you fully charge the battery, and then check the open contact voltage of the battery, it should read between 40.3 and 42 volts. You will need a multimeter to do this.
As a matter of interest, did AlienOcean give you any feedback on the condition of the original battery after it was returned to them?.
If the battery is at the voltage suggested above, you will then need to check for high resistance in the cable that connects the battery to the controller using the multimeter set for 'ohms'. I think that will keep you busy for a while, but further tests may be needed to get to the bottom of the problem.
Have fun
Bob
