You can buy motor cables from ebay; however, it's very difficult to get the cable through the axle, so you should only attempt the repair if it's absolutely necessary, like when the cable is damaged enough to prevent function. Yours looks OK. Does it still work?Where can i find motor cable to change at rear wheel {9 pin}?
Thanks a lot. View attachment 63755View attachment 63756View attachment 63757
No its not working so i must replace it.You can buy motor cables from ebay; however, it's very difficult to get the cable through the axle, so you should only attempt the repair if it's absolutely necessary, like when the cable is damaged enough to prevent function. Yours looks OK. Does it still work?
If the damage is where you show the cable sheath is open, you don't need a new cable. You need to find which wire is broken, cut it open and solder the two ends together. If you don't know how to test, ask and I'll explain.No its not working so i must replace it.
It's not that I don't like it ethically but its for secure.
