http://dillengerelectricbikes.co.uk/electric-bike-kits.html
BALDYMONSTER Pedelecer Mar 1, 2016 51 6 52 Stirling Mar 4, 2016 #1 http://dillengerelectricbikes.co.uk/electric-bike-kits.html
soundwave Esteemed Pedelecer May 23, 2015 16,144 6,315 Mar 4, 2016 #2 id go for the crank motor over a wheel hub any day esp if you want to go off road with it.
BALDYMONSTER Pedelecer Mar 1, 2016 51 6 52 Stirling Mar 4, 2016 #3 Id always go for a crank driven number. What's the top speed of this do you reckon?
soundwave Esteemed Pedelecer May 23, 2015 16,144 6,315 Mar 4, 2016 #4 depends what gearing you have same as a normal bike but id say around 40mph at a guess.
Fordulike Esteemed Pedelecer Feb 26, 2010 3,802 1,537 Mar 4, 2016 #5 You won't get a sustainable 40 mph out of either the BBS02 or the BBSHD. A more realistic figure with a 42T front chainring and 11T rear cog is 25 mph for the BBS02 and 30 mph for the BBSHD.
BALDYMONSTER Pedelecer Mar 1, 2016 51 6 52 Stirling Mar 4, 2016 #6 Do these things have the power output stayed on them?
Fordulike Esteemed Pedelecer Feb 26, 2010 3,802 1,537 Mar 4, 2016 #7 BALDYMONSTER said: Do these things have the power output stayed on them? Click to expand... Depends how they're programmed by the vendor. Don't get bamboozled by power figures. Believe me, a BBS02 48v 25A with factory standard programming is plenty powerful enough
Fordulike Esteemed Pedelecer Feb 26, 2010 3,802 1,537 Mar 4, 2016 #8 ...... but if you're a Gixxer fanatic, then even the BBSHD might not be thrilling enough for you. Maybe a Stealth Bomber is more your cup of tea:
soundwave Esteemed Pedelecer May 23, 2015 16,144 6,315 Mar 4, 2016 #9 also remember the more top speed you want will drain the battery faster so keep that in mind as you will get less range the faster you go.
soundwave Esteemed Pedelecer May 23, 2015 16,144 6,315 Mar 4, 2016 #10 hpc new bike and less than a bomber. Reactions: Fordulike
soundwave Esteemed Pedelecer May 23, 2015 16,144 6,315 Mar 4, 2016 #11 this vid shows how to install 1
