Bad noise break for pro rider e-tourer
Belen
54
Bristol, uk
Hi there,
My pro rider e-tourer has a bad noise coming from the break on the rear while and stops abruptly when using it. It is annoying and scary as it is not working properly.
Anyone knows how to sort it out please?
Thanks guys for your wonderful help
Belén
KirstinS
3,120
845
Brighton
Hi Belen
Can you photo the rear brake caliper and pads please. Photos always help
Look for loose disc bolts, very worn pads, loose calipers, warped discs for starters
Also can you describe a little more detail please.
Is the noise all the time? Is the noise different when used?
KirstinS
3,120
845
Brighton
OK so I actually bothered to look up the bike.
It has a roller brake! Wow
OK, best I can do for you is this thread I found
But to save you time, this is what you need I think
