Bafang Mid Drive Range
doctorprox
May 24, 2015
What kind of range do people tend to get out of the different bafang mid drive kits in a low PAS mode?
I was told that on the bosch powered haibike you are looking at about 30 miles in turbo mode and up to 70 in eco mode with the 400Wh battery
rippedupno1
165
117
Dudley,west midlands
I have a BBS02 750w equipped 29er with the 400wh 48v battery and have done 20 miles at pas level 6 -7 of 9 with half the battery left. I would estimate that 40, maybe 50 miles would be doable at those pas levels. I assume that 70 would also be achievable at lower assist levels although I have never tried this.
doctorprox
May 24, 2015
That's pretty good actually. Are you happy with the 750w kit, I wasn't sure if it may be overkill as pedal assist for a mtb as they also do a 350w and 500w kit
trex
7,703
2,671
I have a BBS01 250W. I get about 35 miles out of a 10AH battery. No throttle, PAS level 1.
rippedupno1
165
117
@ docotorprox, I have been really pleased with the 750w. Power is nice and progressive and the motor incredibly quiet. I have not found it overkill as the controller is programmed so that with the pas you only get 60 % of maximum power even on level 9, maximum power is only delivered using the thumb throttle although this can be changed using a cable and computer as another forum member has already done. Cheers Gaz.
Fordulike
3,802
1,537
Just out of interest, where did you buy your BBS02 and did you program the PAS levels yourself?
I'm not exactly sure what my PAS level 9 is programmed at, but I would guess it is more than 60%, as the display peaks at over 1000 watts at that level.
I reckon that I would get 40-50 miles with my 48v 11.6Ah battery on PAS 1, but guesstimate only up to 25 miles, varying from PAS 3 to PAS 9.
If I were building a commuter, then the BBS01 250w would be the way to go. There is no need for any more power and the range should be amazing, even with a modest sized battery.
X-country bikes benefit from the extra power, for the technical climbs and deep ruts and mud. The BBS02 750w pulls like a horse in these conditions, where the 250w would probably stall.
