Hi. A family member has 7ah cyclotricity battery which is starting to perform poorly lately. It range has decreased and whereas before, it use to take about 3 hours to charge, now it charges in a little over 2 hours. He tried to balance battery by leaving charger on overnight but did not improve things. I checked battery capacity for him (with dummy load) and it appears to be at less than 70% of its stated capacity. It was noticeable with voltmeter that battery was only charging to 40.4 volts (despite charger at 42V) and while discharging on load, battery cuts out at 32.7 volts.
Anyhow, sometime later, with the battery partly discharged, we decided to open battery to check in individual cell voltages and noted a variation of between 3.63 to 3.8 volts in the cells. We also noticed that the BMS is very tiny and contains no bleed load resistors as shown below in photos. ( There is a large vacant area on the small BMS board) I very much suspect, in this case, that the BMS fitted is a 'non-balancing' type and there is no facility to automatically balance the battery.
