Battery chager storck
cyclebuddy
1,553
736
Beds & Norfolk
This is all very cryptic. If the OP would say what is wrong with his charger it may help? Are you looking to buy one, or is the one you have broken and needs fixing, or is it just not working the way you expect?
Redlion
7
South shields
Its not working,and a new one is £100 plus £35 postage thou
cyclebuddy
1,553
736
Beds & Norfolk
Charger went duff
Meaning what? If the LED doesn't light, it could be plug fuse, or one on the internal board. Either can be fixed for 30p. If it does light but isn't charging the battery, it could be an output cable/plug or battery/BMS fault. The first cheaply fixed, the latter more difficult, but isn't the charger at fault.
If you're intent on buying a replacement charger, you need to say what voltage and current yours is, and what plug is fitted - the maker name also helps. Photo's of both the charger label and plug would enable members here suggest possible options.
8,224
Show us a pic of the charger.
What are the symptoms ?
Tbh we have bugger all to go on except you say it's broken.
Do the simple tests first check as mentioned the plug and inside the charger for a blown fuse, also test charge output with a meter. Any positive output reading of the correct voltage may indicate a fault remedied or a more serious battery issue.
Redlion
7
South shields
Checked Internal fuse ok black around a component suggests it burnt out.
Redlion
7
South shields
Component blown need a repair or charger for a 25.2 v battey
cyclebuddy
1,553
736
Beds & Norfolk
The plug on your charger shows multiple contacts: that means there may be some communication between the battery and charger. That makes it difficult to replace with a 3rd party/lower cost/generic charger.
Have you a picture of the internal burnt out component? Like the internal fuse, it may be an equally cheap/easy component to replace. Otherwise, you'll likely need to buy a new original one (£80 on the makers' website last time I looked).
EDIT: Did you check the output with a meter first? Sometimes a component runs hot creating burn marks around it (resistors typically), but that doesn't always mean it's failed.
8,224
Agree with CB that charge connector is far from any std generic type for a two wire dumb system, how many wires from the battery connection lead in to the charger ?
