so guy came to pic his trice up today and there was no power. after a quick bit of missing i found with the charger in everything worked, unplug the charger and dead. now the charger say fully charge, the little lights say only on light so needs charging.
so its 37v 9a sony cells 40 x 3,7v 2250ma. so as it seems nacked i took it to bits.
so first thing i did was check some cells, all the ones i could check are reading 2.75v. the + and - out on the battery case is dead reads 0. so i measured the + on the cells (1) and the - (2) i get 27.75v. so those 2 go to the bms board (3) (4) again i got 27.7v now the final to that go out of the BMS board to the battery connectors (5) (6) i get nothing. if i plug a charger in i get 42v
is it the bms board or the cells. what do you think. tried wiring another chager and it also says fully chaged
