Hi all.
I have my ebike with a bottle battery installed, one of the 36v 10ah samsung celled ones.
Anyway, the problem is, within 20 seconds of setting off, the battery cuts out. If I switch it off and on again, it powers up fine.
BUT....it even happens when the battery is off the bike.
Last night I fully charged it.....up to 41.7v. This morning, I switched it on in my front room, and it was dead. Flicked the on/off switch a few times, and the leds on the top lit up. Left it for 5 minutes, came back, there was a brief flicker of the leds, and then it died again. Flick the switch a few times, worked again, still full voltage.
On my way to work it cut out around 5 times.....not even when using power particularly......cycling slightly downhill on a smooth road, it just switched off. Had to stop and turn the battery off and on again.
This evening it was even worse.....it died every 5-10 seconds.....then 10 minutes no problem....then died again. I tried switching it off and on several times, each time the leds only lit up for a second, then went off.....so obviously getting full voltage at first but then drops off.
I've taken the casing off, and no obvious signs of damage or dodgy wiring.
I was thinking either a faulty switch or the circuit board on top??
