Battery Location advice please
anda1961
40
63
north yorkshire
I have A Haro Heartland Express bike which I want to eventualy convert to pedlec.
The problem is going to be the battery location I know I can fit a rear rack type. The problem is the triangle is limited for space for fitting a downtube type. So I was wondering if it would be ok to maybe fit the battery to the top tube ?. Would this cause any frame weakness problems ? I have attached a picture as you will see the gap is quite small.
Thanks in advance
It would probably be OK, but doesn't make sense. The battery will bring the height up to the level of a normal crossbar. Why not get a cross-bar bike and put the battery in the triangle. The cost of a bike like that is small compared with the cost of the kit and it'll give you a chance to get a donor with disc brakes. can we see some photos of the whole bike, the forks and the handlebar layout?
anda1961
40
63
north yorkshire
Hi I know it don't make sense but I love the bike so would rather keep it normal than get rid of it. I do own a seago folding bike but I want to use my Haro more. I have put a pic of a stock bike but its the same as mine. I will go for the rear rack option if I need too as a last resort.
rich_r
89
32
50
North Yorkshire
You can often fit bottle type batteries on frames with low crossbars - but it can be tight, so you'll need to measure.
Here's a photo of my wife's bike - the battery is just about removable. You can get ones that slide out sideways rather than upwards for this exact situation (but they cost more than I wanted to pay!).
anda1961
40
63
north yorkshire
Thanks rich
yep that look tight fit I will have to get the tape out and do a bit of hunting around but I do prefer the bottle look so if possible that's the way I will go.
Your pic has given me some hope thanks.
5,785
That is a HUGE triangle! Bigly HUUUUGE!
Measure then go look for a HL battery case, check the dimensions, it should fit in there.
16,440
I can see you have not got enough space to insert and remove the HL battery.
if it were my bike, I'll 3D print a triangle box to house the HL battery..
There's several types of those cylindrical bottle batteries. You need the one that comes out sideways.
Ultrafunkula
168
114
Yep avoid rear rack, it's high and weight in the wrong place , makes bike unstable at maneuvering and high speed ,
