Battery
detec52
43
Just need a bit of info, I have a halfords assist electric bike, 24v could I fit a higher ampage to the bike or would it mess the controler up? Say 24v x 10amp I think the original is around 4 amp. Many thanks Rob
Jonah
882
246
EX38
If you mean Battery capacity In Amp Hours (Ah) Then increasing this will cause no problems so long as it’s still 24v.
Reactions: detec52
3,986
Show us the bike you have and tell us why you want a different battery.
8,224
You can fit any 24v battery whether 6ah, 10ah 16ah or one of any capacity, it will increase range and keep top end voltage higher for a little longer. It wont give you more power (watts or speed) but will allow you use the max watts for a little longer.
Reactions: detec52
detec52
43
Yes I'm only intrested in more miles, you have answers my question many thanks. Rob
8,224
With any new battery always test and check the battery polarity is correct before simply connecting up other wise things can go BANG.
