Best front hub kit for a SRAM Automatix equipped bike
Warwick
731
225
Warwick
A while ago I built up a bike using a Ridgeback hybrid frame. I used a SRAM Automatix, 2-speed hub for simplicity. It was intended for a canal towpath commute that didn't happen. It is now a bit defunct, as it's not very good on hills, or, better put, I'm not very good on hills!
Anyway, I am thinking of a front hub ebike kit for it. I would like it to be derestrictable, fit 700c wheels and preferably have a frame mounted battery. Cyclotricity have something that would suit, but I thought I'd see what other suggestions there are here.
I intend to fit the kit myself.
Can we see some pictures of the bike? What sort of forks does it have?
8,173
Other kits:
Panda sell the Xiongda 2 speed hub motor kit but not for disc brakes.
Woosh BPM big bear kit is very good and will get you up the hills.
Cyclezee sell top notch excellent kits.
Oxydrive kits are very good but only rear wheel with bottle battery option.
Or direct route from China like BMSBattery with the neat 09 bottle battery with intergrated controller inc LCD, brakes levers/sensor, grips, pas and plug and play water proof connectors for the wiring and add a wheel/hub, you may have to wire in a speed sensor as a diy job.
Choose the motor winding for your needs high rpm for faster riding, low rpm for great hill climbing or an in between winding for good hill climbing and decent 19/20mph flat speed.
Reactions: Croxden
Before we get all his juices going, we need to know whether any of them can be fitted to his forks.
8,173
True:oops:.
Warwick
731
225
Warwick
What are the forks made of. Use a magnet if you don't know.
Warwick
731
225
Warwick
Aluminium
Can we see a photo of the actual drop-outs with the wheel out?
Swytch Bike
154
68
34
Other kits:
Thanks for the reference Nealh, just FYI to anyone interested we now have the Xiongda kits with disc brake fittings for rear wheel in 48V
Chrisp
Jan 24, 2016
70
I am in the opposite position from you. I have purchased a single speed Reid , then fitted the basic 250w Dillenger with 14aH battery. A picture has been included. I have just ordered an sram automatic for it, as it allows a lot of freewheeling. I run out of puff about 40km/h, so would like an overdrive. Managed top speed of 46 on a downhill stretch today (the speedo tells you things like that). At this very early stage I can recommend the 250/350 kit. The fittings are all colour-coded. Good fortune with your project. regards.
