Hi Jonah, the YTW-06 that I'm using has a 12mm diameter axle with 10mm across flats. I simply filed out my quick release drop outs to a 10mm slot and made the slot deeper to get the axle back on centre line. But I had plenty of metal around the slot to play with, whereas your fork looks very narrow.Thanks for that. Looking at the cycleeze ones I discovered there are different versions for 12 or 14mm axles. So now I’m feeling pretty stupid because I don’t know what the axle diameter is on the Xiongda and I can’t see this measurement on the website tech spec. Potentially worse is that my dropouts are 9mm. Have I made a terrible mistake?
That’s good news. How about filing the axle flats?It's no problem to use your 9mm QR axle with 10mm drop-outs. Many bikes are like that already.
